12
This discussion topic has been answered Discussion topic: Problem with hard disk drive
This message was authored by: Chrish26
Hi, I'm not able to access recordings on my main Q box with a message that says the service is currently unavailable, and when I switch the box on I get a message that says there's a problem with the Hard Disk Drive
This message was authored by: nolte Answer
Re: Problem with hard disk drive
Please see the guide on this article and follow instructions
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
ROI sky Q Customer.
This message was authored by: SlenderRobert
That's usually a sign that the hard drive is failing. Turn the box off at the wall for a minute then power it back on and see if helps. It's probably likely that you'll need a replacement box though so you'll need to ring Sky and request one. You'll lose all your recordings I'm afraid.
This message was authored by: DavidElliott
Tried this but has not worked
ROI sky Q Customer.
This message was authored by: annmarie64
I have a hard drive error and need an engineer
I need an engineer
@annmarie64 wrote:
I need an engineer
Hi @annmarie64   This is a public community forum, it is not Sky customer services. Follow the advice given in the answer.
This message was authored by: marykev
SKY BOXES TYPICAL CHINESE MADE JUNK I HAVE HAD 3 IN 18 MONTHS
Do you have a question?
I've had the same one for 6 years. Maybe mine was made in Lancaster or something.
This message was authored by: HardDiskDrive
Thanks how do I contact sky to sort a new box? Is it possible to phone them?
@HardDiskDrive
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
▪️I AM NOT A SKY EMPLOYEE ▪️
@HardDiskDrive
You have also posted on the Sky+ board so you need to confirm which system you have as one lot of advice will be incorrect.
Answered - Go to Answer
