Discussion topic: Problem getting channels
This message was authored by: Beryl1984
I am having problems getting channels on my tv through sky
Re: Problem getting channels
@Beryl1984
What problems? Any error messages showing?
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Beryl1984
All channels go off get blue screen saying no satellite.
message:  this channel is affected by a problem with your satellite signal. For help press? Great entertainment is still available via recordings, on demand and apps
i have done everything it has told me to do.
whats the use of paying for sky when I cannot get sky?
@Beryl1984
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
Not communial it's my dish.  Might have to wait for move.
@Beryl1984
Not sure what you mean by that. Follow the link and if needed arrange an engineer appointment via the link or by calling.
