Discussion topic: Problem with, sky dish no channels on TV only recorded programmes or apps since Wednesday now tods,n
Message posted on 27 May 2024 03:01 PM
Sky dish not working properly since Wednesday can only get apps or recorded items, now today getting nothing at all
Message posted on 27 May 2024 03:04 PM
Re: Problem with, sky dish no channels on TV only recorded programmes or apps since Wednesday now to
So are you seeing an error message of "no satellite signal"? If so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
