Discussion topic: Power cable
This message was authored by: Heather1573
Power cable
I need a new power cable
Re: Power cable
Hi @Heather1573
If it is the following they are readily available in High street shops and internet
It's a standard IEC C7 Power Cable (figur of 😎
Re: Power cable
@Heather1573
As @oldfella indicates, almost all Q boxes use an IEC C7 'figure-eight' plug, widely available in assorted lengths.
The exception is the v2 main Q box which uses a proprietary round multipin connection into its rear panel together with a dedicated external transformer block: these are available online but can be expensive.  To replace one of those at no cost you'd need to log a fault with Sky, and potentially get the whole box swapped out.
