Discussion topic: My tv is saying updates 1 of 2 for hours
Message posted on 19 Nov 2023 12:08 PM
It is saying on TV updating 1 0f 2 for hours
Message posted on 19 Nov 2023 12:11 PM
Re: My tv is saying updates 1 of 2 for hours
Assume this is a mini box.
First reboot the mini again.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
When the mini is back on with Green led
If you still cannot get past the 1 of 4 step try resetting the mini remote to infrared mode by pressing and holding 7 & 9 on the remote until it's led flashes 4 times.
Then try the 1 &4 again and see if the box respond to the remote. (Make sure that you are pointing the remote at the mini as infrared mode needs line of sight).
Also bear in mind that when it tells you to press the WPS it means on the main Q box).
If this gets your mini working you will need to re pair the mini remote for Bluetooth.
Make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
