Discussion topic: Poor reception and Qbox not responding to remote
This message was authored by: Nev4
Sky Q box tv guide not available no channel numbers bad quality pictures  only volume and channel buttons on remote working can't get int settings or anything
Re: Poor reception and Qbox not responding to remote
Hi @Nev4
First try rebooting your Q box.
If you had to press the standby button on the front of the Q box,  then with the Q box on with green led
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Nev4
Have tried resetting several times no response picture is snowy in small squares and most features on remote not working
