Discussion topic: Poor picture
This message was authored by: Duf
Poor picture
 My picture is breaking up while using the main box as above. Ive changed the hdmi lead and hdmi port but no joy. Only happens while watching live TV which points towards the dish but I dont have the issue while watching live tv on the mini box's which makes me think it's the main box. Any suggestions please and thankyou?
Re: Poor picture
Hi @Duf
Avatar for Duf
Re: Poor picture
Hi, yeah just done all that but unfortunately still doing it.
Re: Poor picture
Looks like the box is faulty @Duf
I have escalated your post.
See following link
https://helpforum.sky.com/t5/Did-you-know/My-post-has-been-escalated/ba-p/3711147
This message was authored by: Brill+Gill
Re: Poor picture
Posted by a Sky employee
Hi @oldfella, thanks for escalating this. We’ve sent @Duf an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Re: Poor picture
That looks a bit like a recent problem in another thread.
Is this an LG? On those reported, changing from 10bit to 8bit colour (and then back again if you like) fixes it temporarily
which points to a cable or TV issue imho but who knows.
