5
This discussion topic has been answered Discussion topic: Poor picture quality
This message was authored by: darkday20
The picture is breaking up on various channels and it's not weather as it's sunny
Re: Poor picture quality
@darkday20
It does sound like a dish alignment issue. Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
Any error message on screen @darkday20 ?
Avatar for darkday20
No also I have no F1 page just a blank pixel picture
@darkday20
Various channels work fine and some are breaking up
I'm going to unplug and reset
