6
This discussion topic has been answered Discussion topic: Sky Q not working over the weekend 16/9/2025 - states no satellite signal has been fine until now
This message was authored by: mazzzy62
I am glad the rewind issues on certain channels have now been sorted.  However out of the blue I am now unable to watch anything as Sky Q stating no satellite signal.  Weather is fine - turned off and on - on multiple occasions - nothing happening.
This message was authored by: GD1 Answer
Re: Sky Q not working over the weekend 16/9/2025 - states no satellite signal has been fine until n
@mazzzy62  Go through the steps here Having a problem with your TV signal? | Sky Help | Sky.com | Sky Help | Sky.com  you should be able to book any engineer at the end if the steps don't help.
@mazzzy62
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Avatar for mazzzy62
Level 2 icon
thank you for your suggestions.  All of which I tried.  though the Service Checker states everything is okay, however still not working.  Its pointless calling Sky Engineers - take about 6 weeks for them to attend as not many engineers around.  Plus in relation to myself having a Communal dish  - the housing authorities  are even worse.  They need to sort out the Communal dish but they also cannot be bothered to climb up.  This they do not consider a priority.  So I am screwed eitherway.
@mazzzy62  Un fortunately if it's a communal dish you're at the mercy of whoever maintains it, a suggestion may be to look at Sky Stream as an option instead?
Avatar for mazzzy62
Level 2 icon
My Sky Q came back to life - so now working - thanks again 🙂
@mazzzy62
Presumably if you have a communal dish you pay a monthly or annual fee towards its upkeep. You need to pester your landlord or housing association. They are responsible for its upkeep and will have their own engineers to contact.
