Discussion topic: Poor picture movement
This message was authored by: Sophielegs
Why do I keep getting the picture breaking up with pixilling patterns breaking across the screen damn annoying
Re: Poor picture movement
@Sophielegs
The current bad weather may be affecting your satellite signal.
Avatar for Sophielegs
Level 8 icon
It does it all the time lately
@Sophielegs
If that's on live broadcast rather than on-demand content then you probably need to get your dish alignment checked.
Level 8 icon
It's both
@Sophielegs wrote:
It's both
Hi @Sophielegs
If it's the same on your mini boxes it could be an issue with the Main Q box.
Bear in mind that you lose all recordings if you have to replace it.
Level 8 icon
Seems worse today so I assume the winds?  But it's particularly bad on channel 512 always notice that
Level 8 icon
Yes I know the winds aren't helping but it's been doing it for a while especially channel 512 I notice  it pixilling it whatever you call it
