Discussion topic: Please wait for programs to load
Message posted on 25 Sep 2023 08:54 PM
In the middle of watching a program on any channel and this message keeps coming up and the program stops and then restarts?
please wait for program to load
Message posted on 25 Sep 2023 09:01 PM
Re: Please wait for programs to load
Hi @Mrsmac3
Message posted on 25 Sep 2023 09:19 PM
Is this the same for sky stream? Sorry newbie here
