Discussion topic: Sky Q & mini box not working properly
Message posted on 25 Sep 2023 08:18 PM
Hi my sky Q box & mini are not working properly.
Message posted on 25 Sep 2023 08:19 PM
Re: Sky Q & mini box not working properly
Hi @Strings
Reboot the mini as above.
