Discussion topic: Pixelating
This message was authored by: Juliebuckle32
Pixelating
Intermittent pixelating on main telly and bedroom telly mini box in spare bedroom hasn't worked for a long time .
Re: Pixelating
Hi @Juliebuckle32
if you are experiencing any satellite signal issues
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
To connect your mini box,
Reboot the mini as above.
