Discussion topic: Sound drops for about 3 to 4seconds.
This message was authored by: jhgf
Sound drops out every 30 seconds for about 3 to 4seconds. This has just started and is on every channel, including apps such as Netflix. I have rebooted , including reset using hidden menu. What I have found is if I disconnect from the WiFi hub and reset Qbox then the sound issue goes away. However of course the Q box loses all WiFi connectivity so no apps etc. So is it a sky WiFi hub issue or a sky Q box issue it happens on all tv's . My gut tells me Sky software issues which they will not admit to
This message was authored by: Addie15
Re: Sound drops for about 3 to 4seconds.
Hi there, @jhgf. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for jhgf
Not had any contact!?
