Discussion topic: Pixelated and breaking up channel 5
Message posted on 23 Dec 2024 05:59 PM
OAPs who can't figure out how to fix it🤷♀️been happening on and off for a while!
need help 🙏
Message posted on 23 Dec 2024 06:18 PM
Re: Pixelated and breaking up channel 5
Dish alignment usually.
Sky will look at it for 'free' but getting an engineer may take days (or weeks) - or pay a local firm.
Message posted on 23 Dec 2024 06:22 PM
@Lyn3395
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 23 Dec 2024 06:28 PM
Thank you for replying. We have switched everything off and on, checked the cables but it is still happening.
How do we find a Sky engineer?
Message posted on 23 Dec 2024 06:32 PM
You'll need to call Sky but you could be looking at the New Year now for engineer availability.
From a Sky Talk landline or a Sky mobile dial 150 to call Sky (free) or alternatively use this link:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and a dedicated 03** UK number is displayed.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a dedicated 0818 ROI number.
(The forum doesn’t allow us to type the numbers in full).
The start will be automated which may try to send you here to the forum or suggest you receiving a text. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
