2
This discussion topic has been answered Discussion topic: Picture issues
This message was authored by: Cakesie100
Picture issues
Hi my picture on both my main box and mini box has gone really black and red picture it used to be really good but now bad .
This message was authored by: Laing1 Answer
Re: Picture issues
@Cakesie100 Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Picture issues
then
Avatar for Cakesie100
Re: Picture issues
Yes I will try that now thank you it's only been since last week when I had issues with my connection but will try that now . Thank you for your advice much appreciated
