Discussion topic: Sky remote not working on Sky Q mini box
This message was authored by Fatfield1953 This message was authored by: Fatfield1953
Hi
pressing buttons nothing happening
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky remote not working on Sky Q mini box
As a first step, have you tried restarting the Mini, by switching off at the plug for a minute?
Fatfield1953
Yes tried that, remote won't turn on the mini, did that manually, checked batteries all ok. Just nothing from remote.
This message was authored by Leethemiller This message was authored by: Leethemiller
I'm having this issue as well the remote has just stopped working. I can't even turn the sky box on and off with it.
This message was authored by Grumpybear1 This message was authored by: Grumpybear1
Remote won't work on sky q minibus
This message was authored by Laing1 This message was authored by: Laing1
@Grumpybear1 @Leethemiller
Have you tried rebooting your Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice
If it switches your box on then you will need to re-pair the remote with your tv
