Discussion topic: Picture freezes randomly
Message posted on 18 Nov 2023 10:02 AM
I have Sky Q and recently the picture has started to freeze at random, as it does during very bad weather, but this isn't weather related.
Message posted on 18 Nov 2023 10:06 AM
Re: Picture freezes randomly
Hi @stewart9
