Discussion topic: My sky q not working, we unplugged and restart many occasions but not working
Message posted on 18 Nov 2023 09:31 AM
Sky q not working even switches off and on many occasions
Message posted on 18 Nov 2023 10:05 AM
Re: My sky q not working, we unplugged and restart many occasions but not working
Hi @Qadir1970
have you tried a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
