Discussion topic: My sky box keeps periodicaly not working
Message posted on 18 Nov 2023 09:31 AM
Sky Box picture goes blank 3- 4 times a day
Message posted on 18 Nov 2023 10:08 AM
Re: My sky box keeps periodicaly not working
Hi @Wayno64
Check the HDMI lead is correctly located at both ends.
Also try another HDMI cable if you have one.
If all seems ok with the cable
