Discussion topic: Picture breaking up/pixelation
This message was authored by: Steven+S
My picture keeps breaking up across various channels and has been now for the past week. I've checked cables, reset my box and as far as I can see the dish has not moved or been damaged, the box tells me I have a strong signal. I'm in the West Midlands, anyone else having the same issues and does anyone have suggestions as it's making it near impossible to watch a programme?
Re: Picture breaking up/pixelation
@Steven+S
Are any error messages displayed because the most likely issue is dish misalignment?
You could check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for Steven+S
Thanks for the info, I’ll make the checks you have suggested, there are no error messages however.
