Discussion topic: Picture breaking up/pixelation
Message posted on 03 Jun 2025 06:44 AM
My picture keeps breaking up across various channels and has been now for the past week. I've checked cables, reset my box and as far as I can see the dish has not moved or been damaged, the box tells me I have a strong signal. I'm in the West Midlands, anyone else having the same issues and does anyone have suggestions as it's making it near impossible to watch a programme?
Message posted on 03 Jun 2025 07:00 AM
Re: Picture breaking up/pixelation
Are any error messages displayed because the most likely issue is dish misalignment?
You could check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
HAPPY NEW YEAR
Message posted on 03 Jun 2025 09:09 AM
Thanks for the info, I’ll make the checks you have suggested, there are no error messages however.
