Discussion topic: QBox won't connect to Sky Router (latest hub)
This message was authored by: TrevGB
Original Sky Q Box + latest new Sky Router.
Box won't connect to the router and says no WiFi connection.
Have followed instructions Settings/Setup - connect to Sky broadband WiFi. Have pressed the WPS button on the router and kept it pressed til it flashes green, however the screen just shows the sky Q box as looking for connection. But it never happens. Have switched everything off/on again. No good. Can't find a reset button on the router. (The home internet has continually dropped since this new/latest router arrived, the previous model was a tad inconsistent but this seems far more unstable and not the improvement Sky said it would be). Anyway, suggestions welcome. Many thanks, T
Re: QBox won't connect to Sky Router (latest hub)
Hi @TrevGB
If this is the new Sky max router then you need to connect it to your Q box as if it is a 3rd Party router.
That is use SSID and password for the router 2.4 Ghz band.
This message was authored by: Jane1962
We had this problem and a Sky engineer called to see us. He told us to physically unplug the router, rather than switch it off. It worked and the Q box did connect. It has happened a few times since, but so far so good with unplugging it.
Avatar for TrevGB
  • Thank you. I'll bare that in mind. The Sky online instructions differ from those on the telly. The online instructions - press WPS for 3 seconds - worked, following the appearance of a blue light on the new max router. Best wishes.
Avatar for TrevGB
Thank you Jane. I'll try that in future. The Sky online instructions differ from those on the telly. The online instructions - press WPS for 3 seconds - worked, following the appearance of a blue light on the new max router. Best wishes.
