Discussion topic: Picture Drops for a second or two
Message posted on 13 Aug 2025 01:09 PM
Hi, possibly 12 months ago a number of customers including myself reported constant picture Drops on UHD channels when using high-end 4k AV receivers. That was eventually fixed but this has now started happening on HD channels. The picture Drops for a second or two every few mins.
Message posted on 13 Aug 2025 01:10 PM - last edited: 13 Aug 2025 01:12 PM
							Re: Picture Drops for a second or two
Tried another HDMI cable?
fwiw I'm using a mid-range Yamaha receiver and have never had either of these mentioned problems.
btw your previous posts seem to be about sound stutters, rather than picture?
Message posted on 13 Aug 2025 01:28 PM - last edited: 13 Aug 2025 01:29 PM
@Paul335 wrote:Hi, possibly 12 months ago a number of customers including myself reported constant picture Drops on UHD channels when using high-end 4k AV receivers. That was eventually fixed but this has now started happening on HD channels. The picture Drops for a second or two every few mins.
Try changing channel, then go back to the one you were watching. I've noticed the picture intermittently going blank for a second especially after ad breaks on channels using Sky Adsmart, this could be the same issue.
Message posted on 27 Aug 2025 02:42 PM
Thanks for the response, I'll try the suggestion and report back
Message posted on 28 Aug 2025 10:30 AM
@Paul335 wrote:Thanks for the response, I'll try the suggestion and report back
Other than that, if you have the SkyQ box connected to the receiver, try connecting it directly to your tv.
