Discussion topic: Paying for netflix and cant get it
This message was authored by: Teddypickle
I'm paying for netflix and most of the time it's freezing and NOT letting me watch
Avatar for Teddypickle
Re: Paying for netflix and cant get it
I'm paying for netflix and it freeze when I try to watch it's been going on for the past month 🙃
Why are you NOT helping with my query
This message was authored by: Invisiblename
This is a customer helps customer forum - maybe your fellow customers are having lunch?
Try Sam9999's advice in this thread:
Answered: Netflix often not working on SkyQ - Page 14 | Sky Community
I am just another Sky customer!
Have you looked at the thread above or below yours depending on recent postings?
https://helpforum.sky.com/t5/Sky-Q/Netflix-often-not-working-on-SkyQ/m-p/4510468/highlight/true#M620...
That would usually suggest the Q box isn't getting enough bandwidth to stream.
Using the 'check my network' option in the Netflix app should give a figure.
This message was authored by: S989
I have the same problem
@S989
If you are seeing the red spinning circle then try this:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4691069/highlight/true#...
You can let Sky know about this issue via this form - https://forms.office.com/e/VGr0tUpv67
