Discussion topic: Sky mini
This message was authored by: Vooman
Sky mini
My sky mini box wont connect
Re: Sky mini
Hi @Vooman
Reboot the mini as above.
Avatar for Vooman
Re: Sky mini
I did all that and the mini box stays on step 1 of 4 and does not progress to step 2 when I press the middle button.
