Discussion topic: Paramount +
This message was authored by: Hudson007
Paramount +
I can't login paramount + or reset my password 🤔 help?
Re: Paramount +
Hi @Hudson007
If you are having difficulty in resetting your Paramount plus password it it likely that you are not using the correct email address that you used when setting up your Paramount plus account.
