32
This discussion topic has been answered Discussion topic: Paramount not working
This message was authored by: MrsSav3
Paramount not working keeps buffering and not loading on Sky Q box. Netflix is very slow to load too
This message was authored by: lettice Answer
Re: Paramount not working
Noticed recently a number of you having some similar Paramount + issues.
Have moved/combined your posts.
Just to make sure.
First try the following if you have not done so already.
Power restart;
  1. Press Standby on your Sky Q remote, then switch off or unplug at the mains and wait for the lights on your Sky Q box to turn off.
  2. Plug in and switch your Sky Q box back on at the mains.
  3. Wait for the on-screen instructions to disappear then press Home on your Sky Q remote.
    Some features may take up to 5 minutes to return.
Refresh your apps;
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
    The refresh can take up to 24 hours to complete.
Try a restart of your broadband router.
This message was authored by: sidellmark
Paramount Plus not working
Paramount Plus is not working.
Re: Paramount Plus not working
On what?   Sky Q, Sky Glass, Sky Stream?
PS your post has been moved from the Sky Go board as this is unrelated to the Sky Go app.
Sky Q, main boxes and mini boxes.
sometimes loads to menu but will not play content.
message says Uh-Oh. An error has occurred, but we're working on fixing it. We'll be up and running shortly.
problem since last night
@sidellmark  Your post has been moved to the correct board for Sky Q
This message was authored by: John6010
Paramount plus
Having trouble logging into paramount plus app on my sky q box. Keep getting different messages such as Internet not working or it just sits on a black screen. Got as far as the menu at one point then it froze.
This message was authored by: Cootie87
Re: Paramount+ not working
Same issue here it's still happening
This message was authored by: bazsarah
Paramount+ not loading
Have tried resetting and rebooting everything. Have updated the app & updated the sky software still not working
This message was authored by: PJR121
Paramount+ app not working
Last two days I've been unable to get into Paramount+ via the app on my Sky Q box. Sometimes I get a black screen, sometimes the logo, sometimes the user list. Twice I've got to the programme page. But a lot of the time I get a spinning wheel of a blank screen.
Occasionally I get a message saying it's an internet issue (which it can't be as all other apps work) or that it's a problem their end.
Paramount+ app works on my TV (but is unwatchable due to sound issues) and on my fire TV in the bedroom, and via my phone. So just appears to be a Sky issue? Bit frustrating!
Just to make sure.
Power restart;
Refresh your apps;
Have done all of these and still not working as of 5 mins ago
Done these too - can't be down to broadband as all other apps - iPlayer, Disney+, Netflix etc. all load fine. Paramount+ is not working
This message was authored by: Sam75
Paramount+ stuck
When I click on Paramount plus it opens amd then gets stuck on the blue paramount plus logo screen and doesn't go any further. I've tried refreshing the apps but that hasn't worked. Any ideas?
This message was authored by: Daverav
Having the same issues on sky glass and even fire stick will not install.
Been happening for last few days upto now
This message was authored by: Michelle19731
Problems downloading Paramount Plus
I'm constantly getting a connection issue when trying to access Paramount Plus. The Sky box is in the same room. It keeps buffering or saying there's a WiFi connection. So annoying when you're in the middle of trying to watch something.
