10
This discussion topic has been answered Discussion topic: Paramount+ not loading on mini box
This message was authored by: megan121
SkyQ- paramount+ not loading on mini box. Paramount+ working fine on main box but not mini. I just have the blue logo but it does not move past this. I have reset the box. i have updated software. i did have a new main box installed a few weeks back not sure if it's related. any ideas
Re: Paramount+ not loading on mini box
@megan121 wrote:
The Mini box (which is the one not loading Paramount+) is Q220 the main box is Q200 (but paramount is working on this one. Trying to update the main box which has been software update in progress for the last 20mins. i'm not sure it's working. you think if they both update to the same version paramount will work?
Hi @megan121
No guarantees but they need to on the same Software version.
  1. Go to Settings, then System Info and highlight Software version.
  2. Choose Setup and then select Software download.
  3. Your box will start to download the latest software. This can take up to 10 minutes.
  4. To check the status of the software download, go to Settings, then System info and highlight Software version.
  5. When it says "Software update successful" press the Standby button on your remote.
  6. When your box restarts, follow the on screen messages. You'll then be on the latest software version.
Hi @megan121
Make sure that the Software version on the main Q box is the same as the mini.
Then First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Avatar for megan121
Hey @oldfella
Thankyou for the reply. I see the software versions are different. How do i get  them to match?
@megan121 wrote:
Hey @oldfella
Hi @megan121
It's the first four digits that's important Q220...... for example.
There is currently a new version being released but not everyone has it yet and it's going out in batches.
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Avatar for megan121
Hi @megan121
Avatar for megan121
I can't believe this it HAS worked. This was super helpful. Really appreciate your support i wouldn't have been able to work any of that out. Both boxes needed software updates and rebooting. All working fine now Thankyou @oldfella
Enjoy @megan121 🤗
This message was authored by: Lyn2907
I'm having the same problem, I've done the software update but still can't get the Paramount + app to load on the Sky Q mini box.
This message was authored by: DebDBakingNurse
Tried this - followed all twice😏
Still no luck with Paramount+ on mini box 🤦🏻🤦🏻
This message was authored by: Sunshine09
I have the same issue as megan and none of the above works
