Discussion topic: Distortions in picture on sky Q mini box
Message posted on 27 Mar 2025 02:51 PM
Message posted on 27 Mar 2025 04:32 PM
Re: Distortions in picture on sky Q mini box
@Mopson wrote:
When playing back recordings or downloads on our sky Q mini box the pictures sometimes distorts and appears to ghost over itself. We are also get little blips in the picture on our main box. It appears to jump slightly or warp.
Hi @Mopson
Reboot the mini as above.
Message posted on 28 Mar 2025 08:14 AM
Thanks very much for your reply. I'll give it a try.
