Discussion topic: Paramount + error code - 3304
This message was authored by: jbailey41
"OOPS!
Sorry, but due to licensing restrictions this video isn’t available in your location. Error code – 3304"
This message appears whenever I try to watch anything on Paramount+.  I have turned the SKY Q Box off and on several times and logged out and into Paramount+ several times.  I have not been able to watch Paramount+ since the SKY meltdown earlier this month.
Re: Paramount + error code - 3304
Can you try the following, even though you may have done some of it.
Remove the power form the Sky Q main box.
Restart your broadband router.
When your router is back up, power back your Sky Q box.
Let it settle for five minutes or so when back up.
Try Paramount + again.
If you are still having an issue using Paramount +, you can then try an app refresh.
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The refresh sometimes can take up to 24 hours to complete.
Avatar for jbailey41
Thanks for your tips.
I had done everything except reset my router so I followed your instructions to the letter and, unfortunately, no joy (although I appreciate you said that the App refresh might take 24 hours, but I did this the other day).
Currently on hold with Sky to see if they have any miraculous solutions but thank you for your help.
Just thought I would respond to advise that there was no easy solution.
We were on the phone to Sky for 2 consecutive days.  First they decided that Sky Cinema needed to be removed and re-added (waiting 24 hours).  That did not work so we ended up on the phone for approximately 2 hours and the Sky representative was very helpful and tried a host of possible solutions (which did not work).  At one stage Sky thought it was Paramount's problem but, fortunately, he was very determined and eventually sorted it (just before I was going to throw it all out of the window!!).  It was something that could not possibly have been fixed by me - it needed Sky's intervention.
My message is "don't be fobbed off, please persevere with Sky"!!!
