18
This discussion topic has been answered Discussion topic: Paramount + error code - 3304
This message was authored by: Rich-peo
Have this msg coming in every time I try to watch anything on paramount +, tried logging out and back in but still the same, network is connected  as can download etc...
anyone any ideas as what's wrong ?
This message was authored by: Lisa-P1987 Answer
Re: Paramount + error code - 3304
Hi there Rich-peo, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
This message was authored by: Rynev
I'm having the same problem today?! Can't watch anything on paramount- error code 3304
This message was authored by: Balks36
I'm having exactly the same when accessing Paramount, Netflix etc via sky tv on my Samsung smart tv.  Was working fine yesterday, not today.  The connection works fine on the other Panasonic tv.... just not the Samsung.  Have great wifi speeds, everything connects and otherwise downloads working fine.
This message was authored by: MarkFranks
I have a paramount + error code 3304 for last 24 hours! Very annoying. How do I get the channel working again?
This message was authored by: MrWilliams
Got this today... Sky issue with licencing for Paramount+ ?
This message was authored by: display_name
Also have this error on sky q paramount plus app, please can someone clarify how to fix this
Turns out my issue was much simpler than I first thought... on the verge of throwing my tv out of the window I thought I'd try turning the sky box off then on again.   Worked like a dream - can't believe I didn't try this first time round!!!
Yep, tried that. Logged out of app and back in too
I forced a sky software update which reset the box - then all came back and working...
This message was authored by: Rodders66
I get an error code of 3304 when trying to log into Paramount + on my Sky Q box. How do I clear it?
This message was authored by: Warrioress
Perfect. Full sky box reboot worked. Thanks
This message was authored by: Julian+Timms
I have had this issue since I got my Sky Q box last month.  Netflix also doesn't work.  I have tried everything and no joy.  Sky sent me a new box. Same issues exist.  What is the solution to getting both Netflix and Paramount to work.
This message was authored by: Mikest
When I try to access Paramount+ I get the error message 3304
I have tried rebooting the TV, the Sky Q box and the internet router but always get this message when I try to access Paramount+. This started a few days ago.
@Mikest
Have moved your post to this similar thread.
Have a read of the posts above and  try some of the suggestions that solved the error for some customers.
