Discussion topic: Paramount Plus wont stream on Sky Q
Message posted on 27 Aug 2025 04:29 PM
Paramount Plus wont stream on Sky Q. Has anyone managed to raise this with Sky or fix it?
Message posted on 27 Aug 2025 04:36 PM
Re: Paramount Plus wont stream on Sky Q
Hi @JamieDebbie I have just tried it and can confirm it is working fine, no general problem. That means it is a local problem with your box or setup. If you have Netflix, try the Get Help -> Check your network to see if there is any local internet problem. Let us know the results. As it is not a general problem, I cannot see what Sky need to fix with their system.
Message posted on 27 Aug 2025 04:49 PM
I have done so, Netflix says everything is OK. It's only effecting the Paramount Plus app, none of the others.
