Discussion topic: Recordings
This message was authored by: Stooky1
Recordings
Message is saying sorry this service is not available
Re: Recordings
@Stooky1
Where are you seeing this message?
Re: Recordings
Hi @Stooky1   In what context? Is this the main Sky Q box or Mini box? Typically you will see that message when trying to play a UHD recording on a Mini box (UHD is not supported).
Avatar for Stooky1
Level 0 icon
Re: Recordings
So it's sky q and when u click onto recordings I get a massage saying sorry this service is not available so can't see recordings or scheduled recordings everything else working fine
Re: Recordings
@Stooky1
Not familiar with that message other than the context given by @MightyQuinn
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
