Discussion topic: Paramount+ 4K query
Message posted on 28 May 2025 01:42 PM
Paramount+ 4K query
I have Sky Q and a premium account with Paramount+. If I watch P+ via my Sky Q box, do I still get a UHD picture as I would if I used the P+ app available on my TV?
75" Samsung QLED Q8F 4K Vision AI Smart TV - 2025
Samsung S60D All-in-one Soundbar with built-in subwoofer & Dolby Atmos & Q Symphony
Message posted on 28 May 2025 02:07 PM
Re: Paramount+ 4K query
Not sure, but I would always recommend using the TV's native App. (It will almost certainly be better quality and not the forced refresh rate the Q imposes)
Message posted on 28 May 2025 03:08 PM
@Mr+Ripley wrote:I have Sky Q and a premium account with Paramount+. If I watch P+ via my Sky Q box, do I still get a UHD picture as I would if I used the P+ app available on my TV?
Yes, currently watching MobLand in 4K HDR, but as @PandJ2020 points out, using a native app such as the one in your TV will very likely be a better picture experience and may even give you the Dolby Vision you are also paying for.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 28 May 2025 06:38 PM
@stereohaven @PandJ2020 Thanks for the replies. I do know about using the TV apps for a better PQ, rather than via the Sky box, I've often mentioned it on here. What's happened is that P+ has been playing up on the TV app, not loading content. I then tried it via the Sky box & it worked okay.
Message posted on 29 May 2025 05:30 PM
To follow up on this, if I can get 4K content to play on P+ via the Sky Q box, why isn't 4K content available on BBC iPlayer via the Sky Q box?
Message posted on 29 May 2025 05:37 PM
hi @Mr+Ripley
I am guessing you have a V2 box (32B1xxxx) - we have never (to my knowledge) found out why the BBC Iplayer version the BBC supplies for this box does not allow UHD
@Mr+Ripley wrote:To follow up on this, if I can get 4K content to play on P+ via the Sky Q box, why isn't 4K content available on BBC iPlayer via the Sky Q box?
I believe it depends on the exact hardware version of the Q box. Someone will confirm with precise model numbers I'm sure. (Or search in the forum)
Message posted on 29 May 2025 05:44 PM
BBC seems to be very picky about who gets their iPlayer & what formats can be used. I have purchased a brand new 2025 Samsung 4K TV this week & the Player isn't included. After doing some searching around about this, it seems to be not uncommon.
