Discussion topic: Our sky tv is not working
This message was authored by: AlexN17
About an hour ago the sound went and we have been staring at a blue screen since. The same applies to our other tvs.
Re: Our sky tv is not working
In that time have you unplugged your Sky Q box for a couple of minutes?  Then plugged back in?
@AlexN17
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
