11
This discussion topic has been answered Discussion topic: No satellite signal after reset and reboot
This message was authored by: IvilAcer
I’ve done a reset of my Q box and now I don’t have satellite signal. I’ve done a proper reboot and still no signal. What else can I do?
This message was authored by: nigea99 Answer
Re: No satellite signal after reset and reboot
hi @IvilAcer
Do you have a communal feed rather than your own dish ?
If so  the chances are that the LNB type is set incorrectly
You need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
hi @IvilAcer
To access it :
press Home
Avatar for IvilAcer
It's cable
@IvilAcer wrote:
It's cable
@IvilAcer In which case the above applies
Avatar for IvilAcer
Hmm, I did that - changed to SCR - and still nothing 😒
Did you fully power down  (not just place in standby) after channging it ?
Avatar for IvilAcer
I did now and... it worked!! Thank you so much
This message was authored by: Lorrainef1983
I am the same but when I do a service check says my broadband ok
Avatar for IvilAcer
@niggea99 may I ask you one more thing? All my apps have disappeared 🫣how do I get them back?
Avatar for IvilAcer
@nigea99 sorry l've misspelled your username
it may just be a matter of time but you can also try another option in the Engineer's menu as above
After entering it scroll down to Apps & select refresh
That doesn't seem related to the problem in this thread. Suggest you start a new one.
