Discussion topic: Our sky tv is not working
Message posted on 30 Aug 2024 10:18 PM
About an hour ago the sound went and we have been staring at a blue screen since. The same applies to our other tvs.
Message posted on 30 Aug 2024 11:45 PM
Re: Our sky tv is not working
In that time have you unplugged your Sky Q box for a couple of minutes? Then plugged back in?
Message posted on 31 Aug 2024 01:28 AM
@AlexN17
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
