Discussion topic: Our sky q mini box keeps displaying no satellite connection
This message was authored by: Bfaye87
For about a week now our sky q mini box has been playing up keeps displaying that there is no satellite connection we've tried rebooting etc and still having the same issue with it
Re: Our sky q mini box keeps displaying no satellite connection
Hi @Bfaye87
First try a reset settings in the main Q box.
Reset Settings is in the Q box hidden menu.
Once the Main box is back up and fully running try rebooting the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
