Discussion topic: Our sky q box does not record, even though recordings are set up.
Message posted on 01 Sep 2023 07:55 PM
Sky q box does not record. If I try to re-record it states that this cannot be recorded! I've tried Turing it off and on again. Frankly I just want shot of it, it's expensive issueless rubbish!
Message posted on 01 Sep 2023 07:58 PM
Re: Our sky q box does not record, even though recordings are set up.
Sky are **bleep** us all the way to the bank. I've been a customer for years and I'm sick and tired of the **bleep**!
Message posted on 01 Sep 2023 08:14 PM
@FThis1 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
