Discussion topic: Hi. We have multi room. The main box is operating fine. The additional sky a box has the three gree
Message posted on 01 Sep 2023 08:28 PM
Our main box is operating fine. The additional sky a box isn't. We can only get a black screen with a header in the top left showing a small white rectangular frame with arrow right and HDMI 3. Tried powering everything off with no success.
Message posted on 01 Sep 2023 08:39 PM
Re: Hi. We have multi room. The main box is operating fine. The additional sky a box has the three g
Hi @John2811
Assume that the mini power light is green (Ie on)
Have you made sure that the TV set is correctly set to the correct HDMI input for the Q box?
Message posted on 01 Sep 2023 08:40 PM
@John2811 and is the mini box plugged into that HDMI socket it maybe the mini box is plugged into a different hdmi socket try cycling through the inputs on your tv with the tv remote to see if its on the wrong input source
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
