5
This discussion topic has been answered Discussion topic: Optical fro Sky Q to Roksan Hi Fi amp
This message was authored by: Tintin27
Hi, I have a Roksan Amp which has two optical inputs. When I connect my Sky Q Box to the amp using optical. I get noise and no signal from Q Box?  Any idea's ?
Avatar for Tintin27
Level 2 icon
This message was authored by: Tintin27 Answer
Re: Optical fro Sky Q to Roksan Hi Fi amp
Back into Settings . Normal was back to digital! Changed it and it's working. Thank you very much!
hi @Tintin27
This sounds like you amp may not be able to process Dolby Digital
If this is the case set :
Home - Settings - Setup - Audio Visual
Digital audio output optical  to Normal
Edit : BTW I have removed your duplicate posts
This message was authored by: lviren
It should work. I have connected my previous and current amp to SkyQ by optical cable. Make sure your digital  audio output optical is selected as normal.
Avatar for Tintin27
Level 2 icon
Thanks, I checked my settings on Sky Q. Set to normal. Sadly still not working ? I have two optical inputs on the Amp one underneath the coaxia I use for my CD player. I thought I shouldn't use that one as it seems to be for the cd?  So I have the Sky Q box plugged into input 3 on the Amp. When I select this channel zero output. When I select input 4 I get a loud fluttering sound which goes away when I unplug the optical cable from No 3 ? I'm stumped.
hi @Tintin27
Do you have a CD player connected via the coaxial input ?
If not there should be no reason why you cannot use that optical input
You may have to look at the manual for the Amp to determine how to ensure you are selecting the correct optical input
My Yamaha Amp does allow me to assign  different optical/coaxial inputs to different 'input' selections.
Avatar for Tintin27
Level 2 icon
