Discussion topic: Open reach
This message was authored by: Dil
Open reach
Open engineer has cut cable to sky Q when fitting broadband
Avatar for Dil
Level 0 icon
Re: Open reach
He's saying if a could be sent the puck through post to correct issue
This message was authored by: Jones_The_Cat
Re: Open reach
@Dil
If you have Sky Q then a Sky Stream puck will not be sent to you as it's a completely different system. You need to ring Sky and explain what has happened. An engineer needs to come back and repair the damage they have caused.
Re: Open reach
@Dil
What you've been told by @Jones_The_Cat is correct. A puck has nothing to do with a Sky Q set up and won't help you if your Sky Q cables have been severed. Contact Sky and explain what Openreach have done and book an engineer.
