Discussion topic: Sky Q box not connected to internet
Message posted on 04 Jan 2024 10:46 AM
Sky Q box no network connection tried everything still no connection
Message posted on 04 Jan 2024 10:49 AM
Re: Sky Q box not connected to internet
Message posted on 04 Jan 2024 10:55 AM
Hi @John1955
Assume this is your main Qbox.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Message posted on 04 Jan 2024 11:19 AM
All sorted thank you
