Discussion topic: On demand
This message was authored by: Gilly1206
On demand
I need to upgrade to watch on demand ontv cn I do it online or do I need to phone if so what is the telephone number.  Thanks
Re: On demand
@Gilly1206 Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
If you have the HD pack or the above doesn't work let us know
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Avatar for Gilly1206
Level 0 icon
Re: On demand
Hi I've tried that it still says need to upgrade.
Re: On demand
@Gilly1206 normally I would escalate this to Sky but there is currently a problem with escalations at the moment so I am unable to do this it may be best now to contact Sky as I don't know when the escalations will be available again
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
Level 0 icon
Re: On demand
Spoiler
Thankyou will do that.
