6
This discussion topic has been answered Discussion topic: Old viewing card
This message was authored by: GeeCrick74
Old viewing card
I have recently rejoined sky after a year somewhere  else. I recieved all the new kit within days but whilst waiting for my new viewing card will my old card work ?
G.C
This message was authored by: Laing1 Answer
Re: Old viewing card
@GeeCrick74 wrote:
I went to Virgin for a year (big mistake). The  original Sky dish stayed up and they just posted me a new Q box and router when I rejoined. I will try the old card and see what happens. 👍
@GeeCrick74 if you had Sky Q prior to moving to Virgin then yes your old card will work
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: bob1234
@GeeCrick74Probably assuming you previously had Q if not then I believe only HD cards that have a 7, I can't remember 1st or last digit work with Q.
It will do no harm to try.
@GeeCrick74 wrote:
  • I have recently rejoined sky after a year somewhere  else. I recieved all the new kit within days but whilst waiting for my new viewing card will my old card work ?
Hi @GeeCrick74  I presume your new kit would be a broadband router, as your SKYQ TV box will be delivered by a SKY engineer who install the box together with a new dish if needed, if you do not recieve a new viewing card the engineer will usually have spares with him.
@GeeCrick74   If you only left Sky about a year ago and had Q they often just send out the Q box and assume that you have the viewing card BUT if you changed to freeview etc and used the dish then the Q box will not work and Sky will need to come out and change the LNB in the box back to a Q one. This does not apply if you went to Virgin as they don't use the dish.
Avatar for GeeCrick74
G.C
Can confirm, the old sky viewing card is working fine. 👍😀
G.C
