Discussion topic: Old sky boxes
Message posted on 29 May 2023 01:35 PM
Old sky boxes
Thought I'd posted this already but cannot find the post. Just had new sky Q boxes fitted and the engineer has left our two old sky+ HD boxes. Can I bin those or pass them to someone else or will sky ask for them back?
Message posted on 29 May 2023 01:38 PM - last edited: 29 May 2023 01:40 PM
Re: Old sky boxes
Unlike SKY Q you own the SKY + / HD boxes.
Once your account is switched to SKY Q then you can;t use the old boxes for SKY but they can be used by others as 'Freesat' watch only - they need a different LNB to SKY Q which will have been swapped for you.
You can take them to a local re-cycling centre or, I believe, it may be possible to send to SKY for recycling/disposal
Message posted on 29 May 2023 01:40 PM
Re: Old sky boxes
@alan+liddellThey are yours to do as you wish with, I would keep them for a bit to make sure you are happy with Q.
However if you want to recycle them use this link to get a freepost label.
https://www.sky.com/help/articles/return-or-recycle-sky-equipment
I
Message posted on 29 May 2023 01:41 PM
Re: Old sky boxes
I
Although we need to point out that SKY rarely allow going back to SKY HD
