Discussion topic: Nothing works
Message posted on 10 Jan 2026 03:52 PM
Nothing works
Message posted on 10 Jan 2026 04:02 PM
Re: Nothing works
@LauraWH16 wrote:
I've apparently got no signal (communal dish) I have network connection but no recordings or apps are available!
@LauraWH16 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Jan 2026 04:16 PM
Re: Nothing works
Still nothing sadly
Message posted on 10 Jan 2026 04:25 PM
Re: Nothing works
Nothing sadly @Laing1
Message posted on 10 Jan 2026 04:27 PM
Re: Nothing works
It may be connected to this overnight Sky Q issue
https://helpforum.sky.com/t5/Sky-Q/No-satelite-signal/td-p/5185796
Have you checked with neighbours to see if they are having the same issue?
Message posted on 10 Jan 2026 04:29 PM
Re: Nothing works
None of my neighbours seem to use sky @Daniel0210
Message posted on 10 Jan 2026 04:37 PM
Re: Nothing works
@LauraWH16
As you are connected to a communal dish you may need to liaise directly with your building management company or landlord who should know if anyone else uses the communal dish and they'll also have their approved engineers to contact direct if needed..
Message posted on 10 Jan 2026 04:42 PM
Re: Nothing works
Yeah looks like my only option!
Message posted on 10 Jan 2026 06:15 PM - last edited: 10 Jan 2026 06:33 PM
Re: Nothing works
@LauraWH16 can you try this
go into tje engineers menu
To enter the engineers menu do the following
press the home button then scroll down to settings and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
check what it says for LNB type if it shows SCR then thats fine (then you would best best to contact the management company as advised by @Daniel0210 )
If it shows Wideband scroll across to highlight LNB type and change it to SCR
come out of the menu
then reboot your box
Message posted on 12 Jan 2026 01:09 PM
Re: Nothing works
Thanks @Laing1 it says scr but thanks anyway
