Discussion topic: Sky box
Message posted on 12 Jan 2026 12:31 PM
Sky box
Cannot get onto Sky the screen is blank. Before it totally stopped working I had error messages.... your hard disc is full?
Green light on box all the time won't go into sleep mode?
Tried to phone but getting nowhere
I have turned off fir 30 seconds and checked my leads are still in .
Can you help
Message posted on 12 Jan 2026 01:18 PM
Re: Sky box
Can you help
Hi @Mathew_91
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
