Discussion topic: Nothing on Sky Q working
This message was authored by jonlee15 This message was authored by: jonlee15
Hi All
help needed I live in flats and issue with the communal dish and awaiting a fix from engineer.
woke up this morning and when I go to all menu options such as recording and apps just getting a message saying to use this service you need a satellite signal
cannot get through to Sky to talk to someone just bots now it seams , may leave Sky soon to many issues and bills going up all the time
thanks all
hhheeelllppppp
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Nothing on Sky Q working
Q will stop functioning after losing satellite signal - either days or weeks.
You need to contact who looks after your communal dish - Sky cannot help you directly.
I am just another Sky customer and my views are my own
@jonlee15 wrote:
Hi All
thanks all
hhheeelllppppp
Hi @jonlee15
Check in your Q box hidden menu that your LNB type is SCR.
If LNB type says Wideband then you need to change it to SCR
After the Change you need to reboot your Q
If it is already on SCR then work  through the following link.  If you cannot solve your issue then as you are on a Communal Dish you will need to contact your Landlord or Management company.
